Im sure youve heard of the term BLUEPRINTING by seeing the term Balanced and Blueprinted Chevy 350.....Im sure alls that pops up in your minds is a set of build sheet type blueprints.........LOL...
At one time many moons ago when I was a kid reading Super Chevy Mags in middle school I thought that too until they came out with a whole Magazine dedicated to blueprinting...
After that my life literally changed but that story is for another time...First the info...
The piston ported or reed inducted 2 stroker engine thats on your mini wasnt designed for vehicles with wheels..They were designed for brushcutters,,augers,,backpack blowers..Basically theyre commercial grade engines the chinese gleaned ad used to adapt these engines quite easily into frames with wheels for us to enjoy......
Unfortunately the thing needs more uumph and more power in order to satisfy the need for speed so the first choice is buying bigbore kits,,hp carbs and exhausts....They work minimally because theyre not refined to maximize their true potential and even if they were youd still only be limited by a bone stock bottomend with flow restrictions.....
Thats where Blueprinting comes in......These crude engines dont have the ability to flow the type of velocity needed to produce extra revs and more lowend/midrange power thats true performance until you BLUEPRINT the low end of the engine case to smooth all sharp edges,,abruptments and shelves that cause turbulence and cause low pressure pockets that interrupt the velocity by scattering it...Scattering causes erratic performance.....
Heres some pics to show you where to look.............
The red lines and the red semi-boxouts in subsequent picture shows where the sharp shelves and abruptments that scatters velocity are in the lowerend
Here youll see the head skirt has been trimmed to eliminate the part that obstructs smooth flow into the transfer ports and causes scattering that causes poor power and performance...The arrow shows the way the velocity is gonna flow....The redline represents the sharp edge thats another hinderance to building performance
Here you should be starting to see how a flow path into the transfer ports is being defined into the lowerend case...........
