1 - 7 of 7 Posts
i copied it from the old forum but here...
6mm x 30 (x2) Handlebars (+ 6mm washers and locknuts optional)
5mm x 30 (x4) Front Arms
5mm x 20 (x2) Pegs
6mm x 20 (x1) Tank
6mm x 16 (x4) Motor
-or-
6mm x 20 (x4) Motor w/ 8 Dampening Washers
6mm x 16 (x2) Brakes (+ 6mm locknuts (x2))
6mm x 16 (x1) Stock Pipe Bracket
-or-
6mm x 20 (x1) Stock Pipe Bracket w/ 2 Dampening Washers
6mm x 10 (x2) Front Fairing Mount
6mm x 35 (x2) Chain Guard
4 Dampening Washers for seat
10mm locknuts (x2) Axles
Also for the pegs, if you lose the little cylinder nuts or they strip out you can use 5mmx30's and drill all the way through. Then use a locknut on the other side.
Dampening washers = rubber on one side.
also...
5mm x 20 (x3) sprocket.
Dude, you rock! I was trying to pull as much of it off the bike and carry it to the hardware store to match it up.
By the way, Home Depot and Lowes were pathetic when it came to finding metric. My best source is the corner Ace Hardware store. Man i spent 4 days runnning from different home depots and lowes across town. Finally found the Ace and man, now it's my one and only source. Downside, Ace are family run stores and closes by 6pm...oh well, can't have everything.
Thanks Again!
Discussion Starter · #7 ·
as i recalled i think it was for cag.
1 - 7 of 7 Posts
