1 - 8 of 8 Posts
I have a new cag with a velcity stack and UFO air filter and want to get more parts for extra speed I also got a 60 tooth sprocket and was wonder if a boost bottle with NOS is worth the money??
No it isnt;-its more of a novelty that lasts all of 3-5 seconds.............Youll get better performance from removing the basegasket and yamabonding the head to the case direct,,rocket key,,chopped flywheel,,lighetned/modded clutches ,, perf exhaust or modding the stock one,,hp wire mod,,NGK plug and walbro style hp pumper carb setup............
Thanks for the help what to you chop the fins on the flywheel with? And what clutch would you recomennd 2 or 3 shoe, and my gearing is 7/60 is that gonna be bad? Sorry for so many question really trying to get more performance
Stormin' Mormon
for the flywheel... im sure there are much easier ways to do it, but with the tools i had and a lack of a nice work area in my garage i just busted the fins off as close to the bottom as i could with angle cutters and then just filed the rest to get an even and balanced pattern
GHETTO FABRICATOR
Score the fin with a hacksaw blade or dremmel then just snap it off and file it smooth or you can leave it raised a little as long as they are all the same.
Hooligan
It's better to build up the engine to go fast all the time than waste the money to go fast for five or six seconds.
1 - 8 of 8 Posts
