1 - 20 of 20 Posts
Hello community
The idea is not new and was also done before from other peoples.
But I've never seen any thread with a small how to and pics.
The idea was how to get more power than a 50cc BZM Engine into a pocket bike. After some research I see that some guys setup a 70cc scooter cylinder on a polini or BZM crankcase. Easyest way is to use a cylinder frome a horizontal Minarelli engine, same stroke only bigger bore 47-47,5mm bore at 39,2mm stroke.
First step is getting the bolt pattern of the minarelli to the BZM crankcase.
Drilled holes and cutting threads.
The cylinder I've got is a used stage6 pro race,
Bolts a Re on the right place, next step will be to fit the cylinder to the crankcase.
Also want to modify the intake to get a vforce reedblock fitted.
Stay tuned 馃馃徎馃馃徎
You should talk to Jordan Sy about this. He did this same thing on his scooterino.
This week the crankcase spindled. Spent some time in the workshop today. Welded engine block for the 70cc cylinder. 馃お馃お
Discussion Starter · #6 ·
So, the next steps have been taken. Milled plan and machined housing. Now the cylinder fits onto the BZM housing without any problems.
I processed an old crankshaft and two bearings that I used to test and measure the squish gap. Should set to about 0,7mm at these cylinders. Next steps will be complete the engine and build a mount for the bike to fit in the engine and build an new exhaust manifolder. If add a few pics. 馃榿馃榿锟硷考锟硷考
Hey Chrisi, Great job on Your housing! Really like how You repaired and cleaned up the damage. What bike is that from? I remember You were selling Your Rsr and Stamas, if I remember correctly? You other bike too? Any Pictures? Just curious .
Discussion Starter · #10 ·
There were no damage, I have to weldup some material for the minarelli cylinder. At the moment I make a 2mm spacer for the cylinder and a holder for the head to mount the engine into a minibike.
For sell is at the moment only a Blata elite 11 Chassi and a GRC gp racing.
Discussion Starter · #12 ·
For a testrun I'll put the engine into the GRC RRZ 3. Then is it for sell.
Wow sweet! Should be screaming machine! Hey take video, just want to see that bike and performance. If you can. That is. Good luck Chrisi, wish you the best!
Discussion Starter · #14 ·
Short update!
Get my reed block today it's a tasinarie reed block with 4 carbon reeds.
I have to mille the BZM crankcase to fit it.
Discussion Starter · #15 ·
UPDATE!!
A few parts are missing馃檮馃檮
Discussion Starter · #18 ·
It's a stage 6 mk2 racing topend.
Available at stage 6 or you get in contact with me馃榿馃榿
I was thinking after the pandemic , I will order a couple items from , You like a exhaust pipe and a top end. But, I have to wait for pandemic to finish. But, I thank You for You knowledge and parts lists. HA HA !... Daniel
1 - 20 of 20 Posts
