Been working on this mod for awhile. I got a new 05T, 6 tooth Cag pinion, 8mm threads and a SS nut, 3/8" SS flat & split lockwasher. Used one of my spare housings w/ the flat spots on the pinion shaft and spring clip on the inside of the bell.
Had to grind flat spots around the round part near the teeth to fit in the bell slot. Then had to cut two small pieces out of a 3/8" SS washer and put them in the slot to push the gear out so the chain does not hit the alum outer housing. Had to grind 3/8" of the length of the 05T gear threads cause it was to long.
Looks Great, using my A2 Cag 54 tooth rear sprocket, & 8mm chain which gives me a 9 to 1 gear ratio. I am also changing the slick tires and rims on my avatar L7 bike to my C1 and them treaded tires on my Lucky 7. Have to drill three holes on the left side of the Cag rim for the brake disc. Since the L7 has C1 front forks, I can put 2 discs up front if I can find a left side C1 caliper??
