1 - 3 of 3 Posts
So, using my new software, I'll be (slowly) creating each and every part of the C1, and adding them with a description to this thread.
First up was the piston, the picture is not complete but it will do for right now.
The C1 piston is a "Dome" top, 2-ring piston, the piston needs to match the head, so to do a "Flat-top" piston, you would need a "Flat top" dome too. (sorry if my rendering looks like a flat top, I'll fix that as I add the rest of the modeling to it.
And soon Ill do the clips, Wrist pin, Needle bearing, Rings etc...
Thanks for looking!
hopefully within a month I'll have 20 parts or so in this thread.
2 Stroke Specialist
cool i just learned something. i thought the c1 had 1 ring and a flat top. idk why but the glare on the piston rings appear to move in your 3d render, some sort of illusion. i think its cool your doing all this work on making 3d models of parts. it would be cool as hell to have a video game were u got to actually build your engines piece by piece.
Here is the Air Filter, It's sized to fit the 14/14 Dellorto SHA / replica carb.
Whats those measurements again guys? (mm) id / od / lenght + the "flange" the rubber where it mounts to the carb (just id)
Thanks to whoever is willing to bust out the measuring tape or calipers for me!
1 - 3 of 3 Posts
