1 - 10 of 10 Posts
I’m looking for the bracket that goes from the frame to the front fairing for a cag mta1 half fairing. Anybody have one you would sell me? Please let me know with a picture so I can verify it’s the correct one I need.
thank you
If you don't have any luck, I remember them being about a quarter of an inch thick, just need some rod the right lengh. You can make one pretty easy.
thanks for the info. Unfortunately, I don’t know what it actually looked like to be able to make one. I can’t even find the correct one doing a google search. If someone doesn’t have one and could post a picture of what it looks like, I could make one
It's just a flat thin chincey piece of steel that screws onto that half welded on bracket on the front of the bike then it's bent like a L with the mounting holes drilled into it 90% of the time the bolts fall out and it falls off or gets completely folded in your first crash. Unfortunately I don't have one because I threw it away along with the front faring it happens about 15 minutes after I got my bike...
I will also look around and see if I have one. One of mine had one welded on, and to have them bolted on but I took all of them off. I only put fairings on for pictures, but for riding I hate them. Can't stand all the fairings on them cruising around. So if I do have one I'm going to have to look in the deep dark box in the corner. Lol
Two different bikes, two different sizes. You can see where they bolt to the actual fairing is pretty different on the two
1 - 10 of 10 Posts
