Try tapping the float with something solid...if that dont stop the flow you may have chunks of petcock rubber seal or o-ring stuck in the needle already............
remove the carb,,,clean it out.,,
set the float a tad leaner,,,only a micro movement..
upgrade the fuel delivery to 1/4"
do the petcock mod...........
After that you should be ok for a bit..............Good luck
