1 - 20 of 28 Posts
hey everybody i was riding my cagllari earlier today and everything was fine. then two hours later i go to ride it and the throttle wont turn ?????
:confused:
what could cause this?
:confused:
The actual Cable, The Throttle (thing you twist to have more fun) or the (Slide???) in the carburetor is what I suspect could maybe be causing your specific issues!
NaSa. :):thumbsup:
should i take out the slide?
I would try it, if you take pictures, it will be easier to get back together too, then you can upload them here to help others too!
Good Luck! You CAN DO IT!!!!
Nicky.
if the cable melted against the exhaust would that make it stick
hmmm, it could! get the slide out of the carburetor, then try it (twisting of the throttle) you will know RIGHT AWAY!
Nice Catch!
NaSa.
pulled the slide and tried the throttle and the spring didnt do anything
im pretty sure the cable is just stuck cause its melted in place sorta?
but i think i can fix it
thanks
thanks
You are welcome!
Thank you for posting!
Nicky.
its like its stuck or something
Did the cable get "Kinked" at all? because under that plastic, is some metal, inside the metal is the cable! if the metal shielding is kinked it would act like you are describing!
Nicky.
Discussion Starter #14
yea i think im going to have to get a new cable maybe.
i got it where you can pull the cable but its hard to and wont
spring back at all
spring back at all
How old are you??? You should just give in and become a mechanic, You learn WAY too fast!
It took me 6 stink'in years!
Good job!
Nicky.
Discussion Starter #18
definitely will be spending more time here ha
also want to ask what a good 100+ dollar mod would be and where to get it?
i checked out pocket bike unlimited and they have some crazy stuff !!!
what about the 16.5mm purge kit???
what mods do you have done to your bikes?
thanks
thanks
What about your bike (specifically) do you want to improve?
Changing the pinion or sprocket (Gearing) is super cheap.
If I had my Hyundai set to top out at 70 mph, it would be *almost*
twice as fast from 0-60mph!
Nicky.
Discussion Starter #20
throttle response, acceleration, reliability...just want to make it "honda" reliable and look cool :D
now im thinking cag was the wrong way to go haha
1 - 20 of 28 Posts
