1 - 14 of 14 Posts
So I recently acquired a Cag in a trade that wasnt running. I got it to run but my problem is the rear wheel is spinning pretty rapidly at idle when on the stand. I've turned down the idle screw all the way until it dies, so the idle being to high is not the problem. Is this a bad clutch? If so there a special tool I need to pull the clutch off or can I just pry it off?
Git R Dun PBracer
Ebay and Amazon has new clutch cheap.
Thanks guys for the input. Any advice on pulling the clutch without a clutch pulling tool?
If you buy a new clutch you dont have to remove the old clutch mount,,,just take the 3 springs w/3 clutchpad arms off the new mount and install them onto the existing clutchpad mount............No puller required with a simple swapover..
But now you need racing springs, or drill holes in the clutch arms to make them better. Are they steel or alum arm clutches?
1 - 14 of 14 Posts
