remove the camgear from the camshaft......install 2 screws and use a screwdriver to flip cam position 180 degrees make sure the T on the flywheel is at the top notch in the case and the camgear *** matches the line and add the chain................you may have to use the screwdriver to get the gear back on..good luck
