Its not too hard..............
Front pinion..........Adding one tooth or removing 1 tooth is like adding and subtracting 3 teeth from the rear sprocket in change
Larger pinion gets more topend speeds but adds engine lag if geared too much......
Smaller gets better bottomend acceleration and torque........
Rear sprocket...............Adjusting the rear sprocket 1 tooth at a time is necessary for finetuning gearing for current track conditions
Larger Sprocket adds torque ...
Smaller sprocket adds topend...
Its up to you to find a balance between clutch grab,,rider weight and track conditions.......Keeping a journal helps alot..........Good Luck
