1 - 2 of 2 Posts
I have have a 49cc mini quad, motor is what comes in a cag. I looked at the clutch(just in mind i just bought it) and the keyhole lock is missing, reason why it was not running. Now this clutch does come and crank does come with it but its missing. Where can i find a clutch keyhole lock? or do i have to buy a crankshaft to get it?
Bicycle with Engine
I've got two Cag engines that didn't come with a key installed on the clutchside of the engine/crankshaft. You can buy them online or bring the engine with you to the hardware store and look in the nuts & bolts section for 'woodruff keys'.
Another option is to buy a rocket key online, remove the flywheel, remove the key in the crankshaft, and then replace it with the rocket key. You can then use that extra woodruff key on the clutch side. Hope this helps. Goodluck!
1 - 2 of 2 Posts
