1 - 2 of 2 Posts
I need a little help on this one....
I adjusted my needle to the 5th postion....in the process the locking nut on the throttle cable came loose & now is totally out of adjustment. Throttle at the grip is very crisp & clean...snaps back with no hesitation...but will not idle. When the throttle is closed, it completely dies....and to start it up you have to twist the trottle just a bit to get it started.
My question is which way do I adjust the locking nut, on the throttle cable at the carb, to get it back to where it will idle & start up like it used too? Thanks.
Turn your idle all the way in,then start it,but if it doesnt start use starting fluid,but if it starts than turn the idle out little by little,until the tire stops moving,but doesnt die.
1 - 2 of 2 Posts
