1 - 7 of 7 Posts
I will be starting up my bike for the 1st time and wanted to ask if this needs to be adjusted ? in the faq in this forum it says :
"3. Move the needle clip on the carb to the 5th position, which is the bottom notch if the needlepoint is pointing down.
but in the how to forums, the tip section does not mention doing this.
So my question is do we have to adjust it or not ?
If it aint broke dont fix it.............
usually move the needle when you do a v stack or filter. or you can play with it and see what your bike likes.
Cool, so just to confirm if I want to adjust the needle, it's located behind the air filter cover (i see 2 philips screws holding the cover on) ?
Does ne one know if the Triple tapered needle off of adrenalinemotorsports.com comes with the 2 e clips (I ONLY NEED THE BIG SILVER CHROME ONE)?If not does ne one know where i can get one bcuz mine is all bent up?...Please help
1 - 7 of 7 Posts
