1 - 5 of 5 Posts
I purchased a 49cc 2 stroke carb for my mototec phantom. This carb had no pulse hole however my engine does. This carb also has no priming bulb (I think that's what it's called) while my stock carb does have one. Will this carb still work with my engine? I'm very new to this so any info helps. Thanks
Administrator
The stock OEM carburetor that's on your engine is a pumper carb which we consider to be one of the best carburetors you won't see any performance increases by upgrading the carburetor alone real performance gains come from things like upgrading the engines crankshaft bearings porting and big boar kits modifications to the clutch and changing the gearing...
1 - 5 of 5 Posts
