1 - 5 of 5 Posts
My cateye started twice, cut off and wont start again. I have a custom pipe and Im wondering if that has anything to do with the tuning any suggestions?
Pull the sparkplug to see what the initial deal is to know which direction to look into for the fix............
Well you need to pull it to see whether its wet or dry..............
Im thinking you either have an improperly gapped coil from the factory or you put the fuellines on wrong.............
If the plug is wet then the coil must be gapped correctly to .020"..........
If the plug is dry then check the fuellines and in-tank fuel filter for clogs
The black line goes on the larger ribbed nipple port..................clear line goes on the smaller smooth return port
1 - 5 of 5 Posts
