1 - 9 of 9 Posts
the part where the screw goes into the engine broke. heres a pic because i dont know how to explain it lol
it makes the chain really loose because the motor leans towards the right and under full thottle the chain will fall off. how should i go about fixing this
<----- loose as a pornstar
Wow Its WEird how your cat eye has allen key headed screws???
Have you tried unscrewing it Taking it out & maybe find another screw with the same dimensions and put a new screw in there....
Get a clear shot of how the transmission is mounted to the engine....It may not be mounted right or you may need a chainbreaker to shorten it.........You could also get a larger front sprocket...........
its loose because the engine mount broke and now there is no tension
1 - 9 of 9 Posts
