You can but its not easy......First Ill say that the cateye engine is the same basic engine as an X2/6/8 engine except for a couple items like engine case color,, e-starter and ignition coil
PBU sells a 2pc headkit but theyre pretty unreliable and the kit is pretty pricey.....
You wont find too many tutorials...Theres plenty of members with threads doing the chop though and doing it with or without the FullCircle Crank..Doing it with a FCC is a very advanced mod...
The reason there are no real threads is because Im the first to do the chop by hand without the use of a lathe or mill....Im also the first to do it with a Full circle crank modded w/piston ported crankrod mod and without...I made no threads on it because itll require a machinist type background to get the lip totally flat and accurately cut or money spent getting a machine shop to do the modifications needed..Some machine shops arent cheap..
I threw the option out there that the 2pc headkit can be done by hand when I was brainstorming with EPR a few years back but hate feeling responsible when other members wanting to attempt just rush to chop then they bust things,,overport things and do things so blind it costs alot of money replacing parts and alot of lost time...
It kind of frustrates me as much it must frustrate them.....They could of just bought the PBU kit and waited eternity to get it and they would of came out neck and neck on that deal....Itll be a sway on the vote on the stress level experienced throughout the ordeal though..
Members like EPR and Fabian7777 have learned quick and done the chop sucessfully...Some not so sucessful......
Tools needed,,,Hacksaw w/finetooth diamond blade,,beltsander,,handfiles,,oilstone,,12x12 totally flat n true marble tile from homedepot,,1000 grit sandpaper
I do my chops with a very fine diamond cut hacksaw...You cut halfway in,,flip the cylinder and cut the other half through............I cut the dome off up high so theres more of the dome left on the cylinder leaving the cylinder hole smaller than the cylinder itself on the initial cut
I set my cylinder without a basegasket and the tightest you should set your squish is .035"...Dont go any wider than .040"..Any tighter than .035" prepare to spend big on fuel.......
..Im pretty sure you want to go methanol so squish should be set to .024"-.028" with a 17:1 dome..
This is the first chop engine...I had more pics but a harddrive crash corrupted them and a ton of vids..This engine was unfortunately stolen a couple years back aswell..
My 56 mph homemade stand-up scooter
