CAM2 please excuse my ignorance, but what's the difference between a cateye and an x2? Can you tell me what mine is? Here's a link to my pics:The Cateye engine I have here has M5 screws and my X2 engine has M6
Heres what happens when you stuff a M6 bolt in a M5 hole so be careful.....I got it this way..After I removed the screw I drilled and tapped both holes to M6
The cateye engine looks similar but has differences.....The cateye engine has a coil with wider mounting holes and the e-starter is a bit different aswell as has a grey fancover case..........CAM2 please excuse my ignorance, but what's the difference between a cateye and an x2? Can you tell me what mine is? Here's a link to my pics:
http://www.pocketbikeplanet.com/showthread.php?t=79868
You should upgrade those lines but I used a small/Micro Philips head screw driver spun fast in the hole to friction heat it up and streatch it.. Then i was able to squeeze it on... Just a temp fix but can work for that old hard line... After doing that let a second or two of gas flow tru the line so it fushes any plastic out..Ok so I got the bolts to my exhaust but now I've got a bigger problem. My black fuel line(not the clear one) was leaking a lot where it connects to the carb. So I cut a half inch off the line and tried connecting it again but no luck, seems like I'm gonna have to get new fuel lines or do you guys know of another cheaper/faster way to get it to connect to the nipple of the carb?
Is that why it's harder to start the bike now? I just replaced the black fuel line with a new clear fuel line I bought at john deer equipment.NOOooOo don't order yet!! Read!! ... Our engines come with a little tube that is about 1 inch long. It connects the gas line to the carb. In other words, that "adapter peice" connects to the carb which then connects to your gasline. I'll post a pic in a few minutes
So the smaller fuel line can still do the job? Will it affect its performance?Good call, I have pushed smaller clear gas line into bigger gas line before to change line size, works pretty good. Make sure you push the primer bulb a few times befroe you start it.
