1 - 9 of 9 Posts
the first chain?
if u kno how to fix a BMX chain, this is easy....
lift up the rear and put sumthin under so its like a stand..
put on the chain on 1 sprocket first
then start at the bottom of the next sprocket and kind of hold the chain there
then start to rotate the wheel and the keep holding it until it goes all the way on...
i dont kno if u understand it, but i could explain parts u dont get...
You can adjust middle chain tension by moving the engine mount forward by loosening the bottom screws (4 large allen screws) and adjust the 2 front "tensioners" to tighten it. Once you got the right tension on the chain (-1" of play), re-tighten the 4 screws on the bottom. Hope this helps.
1 - 9 of 9 Posts
