1 - 2 of 2 Posts
ninja x1 super pocket bike
I have an X1 my rear sprocket is 32 tooth /,5 1/2" putter diameter , 1" inner diameter, 1 3/4" distance from bolt -bolt . What kind and length of chain do I get ? And is there smaller rear sprocket available? Front sprocket is 12tth, 2" o.d. / 1" i.d. is there a larger 1 available? My rear tire says 120/50-9 where can I find rims the ones I keep finding are 6.5
You simply buy a chain that is longer than what you have right now and use a chain breaker tool to break the chain to the proper length after you adjust the chain tensioners to approximately where you want the back wheel to sit then once you get the chain and the master link on then you adjust the slack.
1 - 2 of 2 Posts
