Your clutch pinion is wrong...it looks like a TF-8mm chain pinion and a #25 rear sprocket.....the 25h chain will work after you get the right pinion....
Your upper engine tope screw is missing or the piece is busted off,,,that bracket does more than you know and making a beefier one is recommended...
