1 - 9 of 9 Posts
ninja x1 super pocket bike
Discussion Starter · #2 ·
My X1 started bogging out of nowhere I cleaned air filter and plug still same . My carb has 2 adjusting screws ,1 beside the cable and 1 at bottom of carb . I understand the more I unscrew the more gas goes in . There no vacuum leaks around carb . Which screw do u adjust first ?and any other suggestions?
Look at the transfer case, I believe it says 100 cc or cl on the side.
I can't remember on the carburetor off hand, I will check and get back to you
It comes out to about 3.5 ounces I used ATF in those after cleaning out the nasty paraffin grease.
And what kind of fluid? I was told a 30 weight oil?
You need to open it up and clean the grease out then make sure it's sealed before you put ATF in it !!!
Be careful with it that transmission has gone extinct and you can no longer get it or parts for it!!!
1 - 9 of 9 Posts
