changing the clutch is about as easy as falling down stairs, anyone can do that....You will need the socket to get the nut off the clutch...Drain the oil, pull the right side cover off, there is a plate on the clutch with 4 phillips screws, take those screws out, take the nut off, the clutch assembly pulls off, slide a new assembly on and do the rest in reverse of what you did to take it apart...
If you want to just replace the discs in your housing, take the big snap ring off the back side of the clutch housing, pull the discs out keeping everything in order, replace the discs with the new ones, put the snap ring back in and reassemble.....
You can see the snap ring on the backside of this clutch and the 4 holes where the cover plate goes on the frt side...
This one is 4 $ale if anyone needs it.....
