Cam2,
This should be a great how-to because I discovered an excellent solution that only took me an hour or less to do.
I bought some extra long hard steel bolts from McMaster a very long time ago when I just started my build. They are M6 and 90MM long. They sent me an extra box of 10 for free because the shipping was delayed. Nice people.
Anyway after 1 hour I fixed it. No need to take the entire cylinder off to re-tap and worry about it stripping again later on; in this case with tapping the next size up, I'd rather use a helicoil thread repair option. The entire kit about $16 shipped:
http://www.ebay.com/itm/25-Piece-Th...ultDomain_3&hash=item5ae8eaac6f#ht_542wt_1163
Why? Because I'd be worried about stripping engine threads again.
But then again, there is MINIMAL room for helicoils, so I'm not so sure they would work.
But that's not what I did. I did a 3rd option which has 4 advantages:
1. The easiest.
2. The fastest.
3. The cheapest.
4. Much more reliable than stock.
Here is what I did:
I took an M5 nut, and redrilled and retapped it to M6 size. Thanks to Lowracer from motorbycicling.com for the idea.
Lowracer, however from motorbicycling.com used an M6 size nut so either nut size should fit, I just thought an M5 would fit more perfectly, but with the extra tight fit by using an M6 you would not have to worry about the nut coming off.
The M5 size shouldn't come off either, though. I managed to tighten it really hard without a hex wrench.
Before screwing the bolt and nut together, I spread some red loctite and used washers and lock washers at the top where the bolt goes because they wouldn't fit where the nut goes, but loctite will do the trick instead where the nut goes.
I'm actually happy this thing stripped because otherwise I would not have found this more reliable solution that I can now do to all my bolts and never worry about a bolt coming loose or stripping.
My clone carbon black reeds seem to be good so far. I want to go back to the stock tin reeds just because I was told they will last longer so it will save me hassle later, but I just don't want to go with replacing the gaskets all over again and scraping the stuck on gaskets off with a knife or something. It's a pain to remove gaskets and can damage the engine block casing.
Plus I don't think the black carbon reeds give any better performance than the tin reeds because they are clones.
While they last I guess I will just keep them in there, they seem to be sealing well.
I don't know how to check how well they are sealing and I don't know what will happen if they don't seal well, but if nothing seems to be wrong with my engine and it's running good, then I'm assuming that the reeds are sealing well.
