1 - 1 of 1 Posts
okay after my cateyes fuel line broke i replaced em, i realize my fuel wasnt flowing good enough, put a hole in the bottom of the gas tank and ran my main fuel line through that, my over flow went in through the side on the top. then realised my gasket on my carb bowl was a huge problem of it not starting. so i put a new gasket, then i put the choke on and pulled the pull starter.. it started a lot louder than usual and it ran for a few senconds then cut, i adjusted the idle , ran it again and this time it kept running i put my helmet on to test it and realized when i hit the gas it wasnt going anywhere.. i turned the choke of and tried to start it again and it wouldnt start.. so i put the choke back on and it started then i tried to work my way down on the choke , then when i hit the throttle it died. gas flow is good, i dont know what it is....
*edit* i looked in the gas tank and relized i have no fuel filter.. could that be the problem?
1 - 1 of 1 Posts
