21 - 25 of 25 Posts
Discussion Starter · #21 ·
I got back to squish setting. Started with the thickest gasket and squish was only down to about 1mm so I went down the next gasket and got it just under .8mm. I don't want use the tin gasket because it would probably bring it down to .6mm squish. The motor will make plenty of power as is I don't think I need all that compression I'd rather have the longevity.
What octane minimun do I need to run with the .78mm?
160602
Go with at least 92 then add some booster to get it up to 95.
How stands the piston to the ports. It's always a challenge to get the balance between port/piston and squishband gap.
Normally you should not correct the squish gap with the cylinder base gasket.
Discussion Starter · #24 ·
Thank you. VP makes a 94 octance ethanol free fuel I've been running so I'll add a little booster to that.
The rebuild kit I got came with 3 gaskets. Do you think it is ok to run squish at the .78mm it is now?
What is a good a balance between the piston & ports?
Shouldn't be a problem.
At bdc the top of the piston should be in one line with the bottom exhaust port and the overflow ports
21 - 25 of 25 Posts
