This is a mini atv it's going on?? Where is it not fitting?? On my A2 I got a 1 1/2" brass spacer for $8 and modded it, and put it between the head pipe and chamber pipe.
yeah i've got a 100 amp arc welder and gas welding equipement that I can use, but tubing is not my forte. what if I were to extend it using a shim between the head pipe and the head attachment? maybe I could get the pipe under the parallel support bar and between the foot rest and motor mount?Do you have a welder or know someone with one? Might be easier to cut small Vs out of the pipe bend it and reweld it, think it's SS pipe. You might be able to cut the cross bar and weld it somewhere else.
You should try one of those torkker exhaust manifold spacer/cooler like EPR has on one of his bikes......yeah i've got a 100 amp arc welder and gas welding equipement that I can use, but tubing is not my forte. what if I were to extend it using a shim between the head pipe and the head attachment? maybe I could get the pipe under the parallel support bar and between the foot rest and motor mount?
