Hey guys, anyone know what the height and width on the exhust port are supposed to be . I see just widen 3mm each side but that would not only most probably bust through the case but also would be wider than what i can make the exit of the port ( id bust through to the screw holes if i follow through widening 3mm . ) which i hear is bad.. i also heard something about having the exhaust port area 75% of the transfers , can’t remember why , anyway here are my current exhaust port specs. Height of it at the bottom is good matching up with bdc, i don’t really want to make it higher as to keep the power stroke as long as i can . Please show me the light lol
( the pencil outline is the inside of the port ,
The other measure of the bottom of the sheet to top of port , top of sheet = top of cylinder ( without head) so it’s probably not really tdc.
