381 - 400 of 401 Posts
Wow that thing is really sweet 😍😍😍 there's not a Chinese engine in the world that's comparable to that thing!!!
Discussion Starter #387
Sweet bike, again, how many races have you won??
Update on my engine that this thread started on, I put it on a slight hold while I work on a project pocket bike. I will take some pics and some specs of it soon. When I measured the squish on a "race engine" it must have been around .080. Not good. Even when I took the base gasket out it's still measured way above .050. I took the copper gasket out of the two-piece head and it's finally measured in around .043". My goal is to hit 0.050". And it will have a lightened flywheel, balanced and lightened clutch with HP Springs, pumper carb, dumping the old toilet bowl carburetor, modded reed stopper and plate, rocket key, and a HP wire for the coil. Just a little extra oomph. It is a bike that I am flipping.
Discussion Starter #388
Hp clutch springs and modded clutch. Ported carb from 13 mm to 14.75 front and back. The porting looks rough but it's not, I smooth it out with some sand paper and files. Also tapped out the fuel intake for more flow, a little less than double the size.
No one won, I do it only for fun I'm toooooooo old and toooooooo heavy for races😅😅.
But I know one or two things about 2 stroke engines.
At your cag carb you should normally have some space to the top where you can mill 1 or 2mm so that an oval cross-section is created.
Discussion Starter #391 (Edited)
hey, I'm not saying that the Euro bikes suck. I love Euro bikes.But there are some chinese water cooled bikes that will run with a Euro bike. As the same with air cooled bikes chinese vs Euro. Maybe not as reliable but a good race for sure.
Discussion Starter #392 (Edited)
Unfortunately, my pocket bike builds are slow as I have many hobbies. Mini bikes, dirt bikes, electric dirt bikes, choppers, scooter, goped scooters, snowmobiles, hot rods, RC cars, etc
Discussion Starter #393
Hey guys I know it's been a while. The original thought behind this whole thread was me continuing to advance in the two stroke pocket bike engine area other than the simple bolt ons that everybody knows about. I have done a lot that I have learned off this thread at least in the way of simple stuff, I started to do the deeper stuff and a few projects I had put on hold which will be continuing here soon. In the meantime here's a good one for you. Tell me what's wrong with this picture???????
this was one of the engines I have been modifying over the past few
Hey my friend, the piston is upside down, the arrow points down or towards the exhaust, your triangle piston ports are facing the exhaust port, not a good thing, lol.
Discussion Starter #397
Correct!! Thanks EPR. You know your stuff. That is exactly what I found when I pulled the cylinder head off. The Piston was upside down. Also I had a broken ring. Among other problems with this engine. It looks like somebody threw this thing together with a bunch of performance parts and did not know what they were doing. The Piston is nice and clean like it has barely been broken in. This will be a sweet engine without internal work. But eventually I will do some internal work. This one already does have Boost ports.
I spend my time and effort signing up for promos to cover the cost of all those parts i bought to help the local pocketbike scene. The local scene died out in '09. They say money buys parts and for someone that can build it better.
Discussion Starter #399
Definitely true. I am a little backed up with engine builds right now. Lol. I will have quite a few good engines and limited chassis to put rhem into
