1 - 4 of 4 Posts
When I spin my fly wheel at some points its alot harder to spin like 2 spots specifically (About 140 degrees out of the 360 spin is hard).
I thought there might be a problem with my coil touching my flywheel but when I took my flywheel off and just spun the thing you put the flywheel onto it felt stiff in the same places aswell. Does anyone know what the problem would be? Its about 5x as stiff then it normally is and its started to be a ****off cause everytime I pull the pull start it jolts. I just want it to be a fast and easy startup. Does any1 know how to fix this problem?
Remove the clutchbell cover and look for any damage there........
If there is none remove the engine and pop off the head...it sounds like a c-clip has popped off the piston pin or theres a bearing in the case or crank thats seizing up from poor building or foreign trash being lodged in it.................
1 - 4 of 4 Posts
