What type of engine............?
reeded or non reeded?2 stroke 49cc
How are Nerf Bars going to protect my engine? My engine doesn't hit anything.The cases are pretty weak, maybe you need some nerf bars so the engine don't hit.
Those flywheels have the cluch attached... Remove the clutch and use those bolt holes to push or pull the flywheel off... Long bolts screwed in will push it or a universal puller would work also...
Bumps are bad for catyeyes and X bikes with the Zenoah engines... No Jumping crubs... lol
I take mine off with a centerpunch and a hammer...In the center of the hub theres two indents you can use....I have removed the flywheel plenty of times to replace the crankcase and install a rocket key, so trust me when I say I know how to remove the flywheel...
I was referring to the freewheel on the rear wheel, I know it screws on, but I can't tell which way to unscrew it or how, being there's no notches.
I always ride it on the road, being it's street legal. It's street legal since it's below 51cc, has lights and a horn, and I have it insured with State Farm. That's one reason why I love AR...![]()
Yeah I know, but I was hoping there was another way so I wouldn't have to play with all the little balls inside...I take mine off with a centerpunch and a hammer...In the center of the hub theres two indents you can use....
You dont have to play with the lil balls......Ive taken the freewheel units off in one piece many-many times...Theyre the same as BMX bike Freewheel units.........Yeah I know, but I was hoping there was another way so I wouldn't have to play with all the little balls inside...
I tried taking it off and all that came off is the center ring that holds all the balls in. The center ring is loosened by tapping it to the right. Here's a picture of the freewheel on my bike:You dont have to play with the lil balls......Ive taken the freewheel units off in one piece many-many times...Theyre the same as BMX bike Freewheel units.........
On this twin enginned bike I have a 17tth freewheel sprocket connecting the rear trans to the rear wheel.........It makes pushing the bike cakework......
