Welcome to the Planet....Sounds like your getting acquainted with shoddy chinese craftsmanship......Hooking up a throttle cable is pretty easy
Blueprinting the new BBK will save you tons of headaches....
First things I would do is lube all the cables with a cable lubing tool...if no tool is available then removing the cables and coiling them up in a pan of oil will work pretty good....
Upgrading the carb to a no-nonsense easy to tune-in pumper carb retrofit kit.
Upgrading the stock sparkwire to a better quality automotive high voltage sparkwire
upgrading the crappy pullstarter to an all aluminum one
doing the flywheel mod
adding a rocket key
lightening and modding the clutches
adding hp clutchsprings
modding the stock head with a 3rd port
porting the exhaust port
modding the reedplate and reedstopper aswell as adding a composite reedset
get a jetpro exhaust
Anything that can be done to a cag engine could be done to an S4 cobgra chinese quad...theyre the same engines just diff frames....Good Luck
adding a rocket key
