Noob here guys...
Cag 47cc. I installed the Boost Bottle last night, plastic spacer on the bike, and I DID install the hose barb on the bottom.
So I start it, and it revs at full throttle like mad. I shut it down, figure it's the throttle cable/carb interface, nope appears ok. I go through the cable run and it appears eveything is seated ok.
So I start again, and it revs at full throttle. This time I have it choked and have not a lot of throttle control in the choke position, but when I just start to take it off of choke, it revs at full RPM again like mad, quickly, I give it gas to see if I have throttle response, and I do have some, but I shut it down. I figure it's an adjustment in the throttle pin.
I started it with the throttle pin c-clip in both top and bottom positions with the same exact result. Still trying to chase down what in the ****** is going on. I read that the Boost Bottle port on the bottom end has problems, so I attemp to pinch off the tube out of the port with an adjustable (it's maybe not 100% shutoff, but darn close).
I start again...still rev at full rpm, this time it comes off the stand and almost blasts across the garage. Ok, so it's got to be something in the adapter/reed/carb assembly. I pull the whole thing. No splits in the plastic, reeds are straight, gaskets are intact. I bolt it all back together in a painstaking criss cross pattern turn by turn to make sure that I don't flex the plastic adapter out to cause a leak...everything looks good.
I start again...and AGAIN the SOB revs at top RPM nearly uncontrolably !
It's got to be something with the Boost Bottle I installed last night. The thing of it is, I hit about 34.4 mph with a 100cm circumference setting (the actual circumference of these tires is 86.5 cm), so a 15% decrease in circumference is ~30 MPH, which is not too bad since I'm ~175lbs...
Guys....I swear...I'm ready to run this thing over in my Jeep for an hour and then set it on fire, and dance a freakin' jig around it! This has GOT to be something simple that you guys have run into before. I'm all for getting an entire new carb set up if that will alleviate these issues with a adapter port to accept a top mounted barb fitting...
Guys...I am begging...any ideas ?????
