1 - 6 of 6 Posts
There's a gas leak coming from the bottom of the bowl!!! How do I solve this?
This is on the x18!
NO GOOD DEED GOES UNPUNIS
ya that screw is to let the bowl drain like it is
screw it in and it should stop
if its not the bowl drain then there is an overflow if the float is stuck down and it cant shut the gas off
the only mods i do to the stock carbs is the 'removal' mod
i think they started putting loctite on things so that might be the case
plug the hole with your finger and see if it comes out somewhere else
if it does then the flow isnt getting shut off by the bowl rising so it may be stuck down
i usually smack mine with a screwdriver in the bowl when that happens, not that its the right thing to do but for a quick fix it works
1 - 6 of 6 Posts
