Where is 1st supposed to be all the way up or down or I between 1st and second the gear indicators kinda suck I had that problem as well its mor than likely not in neutral try going to first with you hand and slowly pulling it up in-between gears to find neutral as for the drivability issue is it fine in the rest of the gears and how does the plug look is it black
