ok so on my cateye i ajust the cab right and when i try to ride my bike wont move idk y can so one help and yes i turn the coke off and it a good spark and plug and good fuil, and i let the bike warm up to plz help
how long have you been using the same clutch? it might be glazed, and the clutch bell too. glazed = no clutch lock up = the bike doesent move. maybe your clutch has no more pad material left too.
Im having the same problem but can the cylinder where it mounts be the problem... Like when I hit the throttle it doesnt move but the clutch is good. I have used this gasket maker on the cylinder and Im thinking I didnt seal it up right...
You have to use a high temp sealer. I used it on my motor didnt have a problem. I got some copper gasket sealer temp rated at 700+. To get it sealed good you put it on the part thin layer then let it sit for 15min then lightly mount the part. Then wait 1hr. Then torque it sown then let it sit for 24hrs before starting the engine.
1 - 7 of 7 Posts
