1 - 6 of 6 Posts
Hello I have a 125cc 4 stroke Manual Clutch 4 gears engine from a pit bike... but i reallice that pit bikes a super pocket bikes have the same engine or almost....
So i bought a pit bike with this engine that was a little messed up.
Missing 2 side covers and i think something more, that is what i need to know :p
here some pics
http://imageshack.us/photo/my-images/696/sany0124.jpg/
http://imageshack.us/photo/my-images/708/sany0125j.jpg/
http://imageshack.us/photo/my-images/833/sany0126c.jpg/
Thanks for the ones that helps me :D
I have the air filter but i took it off.
I sprayed WD-40 to the rusty parts in the engine... Do i need to lub it? What do you recommend me?
Thanks again :p
Hmmm, Blitz and the guys will know best, I'm not good enough (YET) to spot missing parts on the 110 / 125cc 4-strokes! :(
They should have a parts list guide, that would usually have an exploded diagram of the engine, I bet you could use it to spot missing parts...
WD-40, make sure to try and only use it on external engine parts, some 4-stroke engine oil is typically pumped through the engine to keep the cylinder / head / bearings lubed...
And for the oil, 4-stroke "Wet Clutch Safe" Motorcycle oil from an auto / motorcycle shop should work great!
Good luck! and Nice Find!
Nick.
Its gonna need a clutchpack,,,countershaft gear,,and the side cover complete on the right side......
Hello Thanks for the answer :D
Cam are you sure it needs clutch pack and countershaft gear? I bought the right side cover.
But I hope i only need the clutch pack and the countershaft... is that the only things that i need? Thank you guys for the answer.
Somebody else know what I need too?
Thanks Guys.
Hey Blitz thanks for the pic it helps me a little bit more :)
Could you help me compare your engine with mines and if you know the names of the parts, could you tell me?
As you can see... Im new at Pocket/Pit Bikes so I do not know almost nothing.
I would like to know what the parts are called and maybe where can I buy them a little cheap here in USA.
I live in Florida, Miami if anything hit me up.
Thanks :cool:
1 - 6 of 6 Posts
