Hi guys. My walbro 603 wasn't leaking fuel from the air intake until the other day I used compressed air to clean my Carb up. I think I messed it up. Now I need help to fix the leak. What part should I fix?
Yes the one internally.............U were talking about the lever. U meant the lever located inside, underneath the primer bulb? Sorry I don't know much about 2 stroke. I used to be an auto mechanic, now I'm a welder. About 2 stroke. I'm stupid
check valve opr accelerator pump?Thanks cam. I got it fixed now. It was the diaphragm that got messed. N found out that it also has a checkvalve. Luckily I didn't mess it up otherwise I have to throw it away.
