1 - 4 of 4 Posts
;) hi im haveing problems with my polini bike if i ride it and hold it full throttle it dies out about 100 ft away if i ride at about half throttle it runs fine what is happeneing?
If your gas is turned on, then it sounds like the clutch needs adjusting. When the springs on the clutch shoes are too loose, it engages at low rpms which will cause it to bog down as you increase the throttle. It could also be a dirty fuel or air filter, these little engines need to really breath. I would check both filters first though as that is the easiest to check.
yep
probaly adjust the clutch or replace it. check the carb as the fuel contains aliumullion and it stops the bike running cleanly
hope this helps
jonny
OR, check out my thread on dieing. Well if u see a gold thing by ur motor, twitch it to the right, or the left if the right didnt work. My pocketbike did the same thing too.
1 - 4 of 4 Posts
