Okay great check your gaskets sometimes the gasket will half cover the vacuum port that powers the pump
There is a low speed idle adjustment accessed through the top of the carburetor.
Sometimes it's glued and other times it will have a little rubber plug that you have to pop out I just squirt a little bit of brake cleaner inside of there and let it sit for a day to loosen the glue.
Some of them do to the EPA have been made non-adjustable ( no slot for a screwdriver) if you have one of those ones you will need to replace the carburetor to adjust the low speed needle.
[/QUOTE
