So, I just picked up this X1 from a homeowner that was moving and he didn't want to take it with him. When I first got it, it didn't run. But it did turn over. Well, when all this first started (when I first got the bike), I didn't know nothing about these little bikes. But after having it a few weeks, so far I took everything apart. And I mean EVERYTHING. I took the frame, I sand blasted it, then put a coat of powder coating (Black gloss) on the frame, I then followed the same process with the rear forks, but I painted this part Machinery Grey. I didn't have to do anything really to the front forks but degrease the bearings in the front part of the frame (I can't remember what this thing that holds the upper and lower bearings is called) then pack the bearings full with new grease. I then took the axels, front and rear, and cleaned, deburred, polished, then regreased. I got a new wiring harness and wired it all up real nice. I then got into the engine. First, I ordered a 43-49cc Big Bore cylinder head, piston and rings, wrist pin and clips, I got new crank shaft bearings and seals. I ordered a HP carb (not sure what brand it is, I got it from scooterpartsforless.com), it came with the v-stack, HP airfilter and gaskets. I took apart the started and trans and cleaned and added new 80w90 gear oil to the trans. With the started, there were some loose connections so I re-soldered those. I then ordered a new engine case for the 49cc engine, I got a rocket key, and a new coil (I got the coil cuz my old engine was a 43cc and the new engine was going to use the 49cc coil, and with the Big Bore kit I got was going to make it a 52cc engine. So anyways, I also ordered a 19 tooth rear sproket, and a new gasket set for the engine. I also took the forks apart and cleaned the springs, deburred and polished up the metal parts and regreased it all up. I was going to get a HP clutch, but it already had a aluminum clutch in it, and I read that from the gfactory it came with a steel clutch, so thats got me puzzeled. So now, I just about got it all back together but I dont want to get it all the way back together just yet. I'm wondering is there anything else I should do before I get it all back together? I do want to get a fatty exhaust pipe, and a blast box. But is there anything else I should get? And where to get it?
