Looking to upgrade the minimoto from 18v to 24v for the time being. Would like to set myself up for possible 36v on the pr200
good idea to do the homework first... if better means cheaper, then yes you can buy most of these parts from aliexpress to save a few bucks over ebay.Both are have no battery and before i start buying parts, I'd like to start on the right foot. Also if buying separate is cheaper, are therebetter places than ebay?
i dont know about them hobby king bats they tend to wanna puff more then likely the reason they are inexpensive Max Amps are good never puffed not one and they hold what they say they will and you can use all most all of it.
but then you need the charger
if you use power tool battery's most of them have the low voltage cut off in the battery so you dont have to worry about over discharge and it going nuclear
lead acid sucks they are slow charging dont last have a poor power density they are freaking big and heavy if you crash and one breaks open you have the acid to deal with but i guess they are cheep you can get them for 12$ each online 25 at wallmart
Once I saw a video where a guy did a 36v battery & speed controller swap upgrade on these where he claimed the motor that they came with is actually a 36v motor reduced to the 18v by the factory with the stock controller, but can find it or anything else like those instructions anymore. Does anyone here know how to & may be willing to share with me to pull off mod? Thanksmonsterscooterparts.com
has all the parts for this bike. But all the parts for this bike are
also comparable to the razor 200 pocketbike.
search the sit for honda minimoto!
I have 1 of these bikes and modified it to a 350 watt 24 volt motor.
3 12 volt 10 amp batteries and a 24 volt controller.
bike goes 27 mph on a slight downslope. lots of fun for the kids.
also changed the belt drive to chain #25
Chip Douglass
Any 36v controller paired with a throttle and run 3 lead acid (cheap) or a lithium. I have used 2 hoverboard batteries in parallel work great.i charge them off a hoverboard. Other than some wiring, a fuse or breaker, and a power switch that's all you really need.Once I saw a video where a guy did a 36v battery & speed controller swap upgrade on these where he claimed the motor that they came with is actually a 36v motor reduced to the 18v by the factory with the stock controller, but can find it or anything else like those instructions anymore. Does anyone here know how to & may be willing to share with me to pull off mod? Thanks
