1 - 4 of 4 Posts
i add 2 stroke oil with my gasoline i mix it, but it also needs oil in the motor, like the gear box. Because i opened it and looks old and stinks. how to change it? what kind do i pour in? how much? how much it will cost? what brand?? please let me know!!!!
I would you non-detergent 30wt engine oil in the transmission, about 100ml or so, not to much just want to lube the chain and bearings inside.
I think it is 100cc of oil. You might ask an auto store where you buy the stuff, if there is another lubricant that would work in the trans, which I believe is just a gear reduction box 2 gears & bearings and a #25 chain and to move the chain back closer to the swing arm bearing so the chain don't rub the frame when it goes up and down. On my 125cc ATV Automatic trans w/ reverse, having a reverse it's so nice for getting out of tight spaces,lol.
1 - 4 of 4 Posts
