I have a few ideas on how to improve on most of these points, if I ever do something about it then I will make a new thread on it.
That info was actually from on here, but a real long time ago, but as I said it doesn't matter anymore
I agree, use barrel intended for a 44mm piston, turn up a cast iron sleeve, cut the windows in it, press it in, do the final cleaning up / surfacing, hone and then fit a 40mm piston.
I dont know where youre gonna improve on sparkplug indexing but whatever floats your boat,,,no two sparkplugs are threaded the exact same unless hunted for.....
As far as your comment about what doesnt matter anymore about two stroke timing then why even bring it up?...
Just keep telling yourself these are industrial engines .............
Ive built these small cc engines from 18cc to 108cc every which way to sunday and done quite a bit of refinements on these engines with dual carb hybrid engine builds over the years running them on alky/methanol and yet to this date people wont do or try it because of the technical standpoints to the builds that 70% dont have the capabilities of performing on these lil engines and are content on what comes out in the wash doing a straight up build with what they get through the mail......
Ive yet to experience any type of seizures n such problems the others have experienced throughout the years and have shared the horror stories.............reason being the industrial engines are built retarded naturally to deliver descent torque while maintaining life longevity.....even if you make them racing engines they arent truely race engines without resleeving and remapping the ports..........Thats a process nobody will want to tackle but has been done FYI but wasnt feesable as heat breakdown was its #1 enemy after 10 mins of runtime ...
The only way is to cast up cylinders similar to stihl 2 stroke engines and producing them for the reed inducted market...............
We had a member named Mexicano......He was a very very thorough guy.....He went through every aspect of two stroke tuning/engine building that most of us know but with this chinese crap isnt too critical seeings theyre Industrial tool engines....
Cant recall hearing the work of art ever start n run but was a thorough build thread none-the-less.........It was an all-time greatest documented build-up on a chinese cag engine Ive seen all of the forum and yet its gotta be found to know it exists......Even Benefields Wickedly built Polini powered chinese miniquad.........That quad was insane and the guy who built it was a madman also a genius ........
Id love to hear what you come up with on port calculation numbers and how youre gonna fix retarded porting without smashing the piston off the dome...
Basically what I want to know is,,,,Whats gonna be your major point to your thread?
Is it to educate others as to the correct ettiquette to building small cc chinese made 2 strokers and show your truley a more superior two stroke build genius amongst us all?
If so theres a member here named rcfish90 building a whiz-bang of an engine yet you wipe your feet here instead of lending your expertise there.....kinda tells me theres something a lil more to the plot so I may go grab some popcorn with light butter and wait for it to thicken.....:tango_face_devil:
I really dont think too many will care about the extra thorough buildsteps especially the guy buying the engine unless it breaks some world record or something along that highway............LOL...
The hits on the previous 2 stroke refinement build threads throughout the years have proven that point especially this thread count....
Back around 2008 you couldnt get a straight answer out of anybody about squish and porting a 2 stroker,,,,everything was super critical or hyper critical etc written in degrees and technical terms making the layman scratch his head.......
One day I made the process easier when I threw out the dimensions and the technique on a much different scale that 75% could grasp and actually perform over the 15% previously who were doing it with milling machines and not by hand with a dremel or files n emery paper.................not everybody has access to a milling machine so anything taught on the subject using such a device is kind of a moot point...........
Only a dozen or slightly more I know of tried refining an industrial engine to make it an actual purpose built racing engine over the many who said theyd love to do it but dont have the tools,talent or the place to do all the work...
Those that did the extra work were very happy they went the extra step because they were actually racing their chinese junk and it made a definate improvement.........
Do a build-up on a whole bunch of non-running bikes or build an aircooled cag that will compete with the watercooled 50cc eurobike racing classes and most will be more interested.......
