1 - 11 of 11 Posts
It's a CatEye, I would say it's the most common Mid-Bike.
I have 2, it is (close to) "49cc" it's a Piston Port (instead of reed ported) 2-stroke...
Check out the 2-stroke Mid-Bike section for more information.
2Stroke Midbikes - Pocket Bike Forum - Mini Bikes :):thumbsup:
thx so much it has a oil leek some where i am not sure though wat do you suggest i look at these one guys thick its comeing from the exhaust
Don't worry, that is really normal, the gas and oil get mixed together, if there is a small "exhaust" leak some of the gases + oil can leak, just wipe it down, and if it's too bad pull the exhaust off and clean it up, then put it back on.
Have fun, and feel free to ask any other questions, I've had them since '05
Good Luck! :thumbsup::)
O.K. it's exactly like my cateye, (standard) except your's has the "Jack Shaft" which is that in between section with the smaller chain.
Not the CVT, and Not the "reverse drive" gear reduction.
Cool bike! you are going to have lots of fun!
That's what the gauge says, but actual MPH will be around 30....
that is pretty fast when you are riding it, my water cooled C1's only do 40 or so, and that is super fast that low to the ground!
And yes! it is a GREAT beginner bike, you can beat the crap out of it, and it will keep running, just be sure to mix enough oil in with the gas (2-stroke)
1 - 11 of 11 Posts
