1 - 3 of 3 Posts
hi, everyone. I just bought an x7. It's a 2 stroke without the harness wire and without front lights.....a week later i bought the front light and harness wire but the harness wire does have the plug for the front light but not for the switch to turn it on and off so i want to know . It's a 2 stroke
the questions are
how to connect the front light to the engine so when the engine start the lights too and what is the electric box (brain) cuz i dont have the EB. TY!!!!
should be as simple as connecting one wire to ground and the second to the run terminal on the key switch. problem is this will probably overheat the key switch causing it to fail. a better way would be to get a 10amp toggle switch, one wire to the switch and then ground and the other wire to the power side of the battery.
Hugh
SDscooters
1 - 3 of 3 Posts
