i think my clutch went out
1715 Views 19 Replies 5 Participants Last post by  CAM2
sounds like spinning metal and no tire movement. can clutch springs be found at Lowes? i hope its just the spring and not the whole clutch.
any special tools needed?
how hard is it to fix?
pics and video links would be awesome
thanks
1 - 20 of 20 Posts
Im not sure but a new clutch is like $20 at monsterscooterparts.com but i dont recommend buying thier pullstarters, i went through 2 in three months
Its not hard to do,,,you do have to remove the transmission to get to the clutch.....Id pop the flywheel,,lighten it and add a rocket key while youre opening it up..You could also mod the clutches foe performance...Cheap clutches can be found on ebay.........Good Luck
thanks i was wondering about what else could be done while i was in there. haven't taken it apart yet so I'm not sure if i have to buy a whole new clutch or just the spring. so i just ordered the HP spring for the time being.. ill update you guys tomorrow when I've had time to look at it.
quick question what side of the motor is the clutch/transmission on?
its what the chain is hooked up to coming from the engine.......
Sounds like your clutch shoes have worn down to metal, a new spring won't help that at all.
How can you mod a clutch for performance?
crossdrill the pads to lighten them and add a stiffer spring so the clutches throw out later at a higher power rpm.......
Here is the clutch on my Hot Rod engine.
this is what i found upon taking it apart. i dont think its the clutch but im not sure. i didn't see the bell part at the usual website i go to. any Ideas where to get a new one? what is it? and do i have to take the clutch bolts out to replace the spring. thanks so much for all the help guys
That bell is wasted. Check out PB Parts in Florida. Click on the icon for your bike.
Look at the clutch EPR its a gonner too....That thing sat outside
After seeing that bell I was afraid to look,lol. ADA racing online line has some pocketbike clearance parts I got in the mail today, billet fork tube top caps , small and large w/ O ring, $3.95 a set. Got a Cag clutch bell w/ 10mm threads $3.95, billet WA/WT throttle arms for Walbros on a Cag engine $2.95, big hole billet cag V-stack w/ SS screws $4.95. CAM2 better go check it out.
The best clutch mod I done for my X1.............The bike takes off like a slingshot........
Wait the clutch is on the outside of the flywheel? Like a reverse? Whats holding it on there? Or am I just trippin? lol
LOL youre not tripping,,,the pics of the process werent quite in focus and when I gotta do a pad change on the clutch on the x1 Ill take clear pics of how its mounted..
Its not that hard to figure but Ill just say you cant go back to a normal clutch again unless you buy a new flywheel.....LOL
The main clutch arm points are the new mounts via some fabricated posts out of grade 10 studs from streetbike caliper slider studs,,retapped and cut down then grooved for the clip.....The original clutch bosses on the flywheel face were shaved off flat because they were in a bad spot...
You seen this one too right..........I got this setup in my stand-up scooter but with crossdrilled shoes and another engine aswell...
I had to get rid of this problem......
Nice, Super mod 2012~~~ You then just create a Prawl and put the pull start on the other side of the Crank shaft huh? You sure do take it to the limit...
Love this Clutch! http://www.pocketbikeparts.com/Clutch_Cobra_Rock_Eton_42cc_p/rkcl301133.htm
The You Tube Buttons Gone..... :( http://www.youtube.com/watch?v=YwASii2f5c8
lol
oH, Nevermind... Its still there just not after you type in Quick reply then hit advanced... Phbb bug..
:thumbsup:
lol
Its already there...LOL
1 - 20 of 20 Posts
