1 - 8 of 8 Posts
marcelo My brothers bike is idlin at full throttle? I checked the idle screw and its definitly not it. I am thinking it the actual cable but not quite sure? If anyone can help it would be great! :thumbsup:
Pull the air filter off the back of the carb and watch the slide inside the carb as someone operates the throttle. It sounds like the throttle needle isn't making it into the emulsion tube and getting stuck or there is a nasty air leak somewhere. Or...someone has really misadjusted the throttle cable screws both at the handle bars and at the carb.
when i was trying to put the throttle cable and slide back into the carb it was a big hassel.. then i realized that there was a little notch where the idle skrew hits.. make sure ur slide is put in right
1 - 8 of 8 Posts
